nickthehunter
Jul 03, 2013Nomad III
Have you ever used this trailer connector before? Is it one turn signal or both? Generally, the stop lamp and the turn signal are the same wire, but not always. If it's just one turn signal, that narrows the problem down to one wire. You need to get a volt meter and check the one wire and figure out the problem. If it's both turn signals, all bets are off.
44,071 PostsLatest Activity: Aug 30, 2026
