gocamping14's avatar
gocamping14
Running Lights Stay ON
2019 Rockwood Mini-Lite. camper parked, not hooked to vehicle. plugged into shore power. rear running light on ? must be a short. suggestions are to check plug on trailer for moisture or corrosion. any other suggestions for a short, thanks in advance.............ss
  • Are the lights on w/o shore power?
    I'd check the charge wire for a connection to the lights. Take the plug apart and check there first. The charge line should have a fuse, pull it and see if there is any change.
