tcbkenpo's avatar
tcbkenpo
Running lights problem
I have a class A 2009 sport coach elite Coachmen and I Need new running lights and lenses. Cant find this model
TMC-GLO-Brite 122X88, this is what is stamped on the back of lense.
I need 6 full sets. I have been looking for a long time and can't seem to find the oval ones I need to fit.
I do have photos of light and lenses, but I can't load to forum
  • Here is the part. It fits perfectly in the recess.
    http://greatamericanchromeshop.com/shop/index.php?main_page=product_info&products_id=3487
  • I just ran into this issue also on my 2008 Elite for my side marker. I found a led lamp at a Chrome shop that worked perfectly as far as fit. I did have to open up the bolt holes with a 1/4" drill bit and open the hole to allow the back of the lens to fit. I also had to run a ground wire from the existing 3 pin flat plug to the light. I'm sorry not sure how to post pics
  • http://76.12.98.46/heavy_duty/part.cfm?part_id=114BC5EE-6A2E-FF26-35AF12283FBBADF9
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Visit a CHROME shop are you planing on replacing the lens or the entire light??
    If you can not find the lense get an LED marker/running light assembly that is slightly larger than the existing and replace the entire assembly.
    What is a "Chrome Shop"? Bling for Truckers.. Look up the I-90 Truck stop in Iowa on Interstate 80 It is ONE of many such shops scattered around the country but it will give you a clue as to what to look for... Largest in stock selection of lights I have ever seen was the I-80. Other "Chrome shops" are not far behind (if not better, I've only been to a few of 'em and one was .. a long long time ago).
  • Can't go to something larger because light insets into the RV's body. I found out that GLO BRIGHT is out of business so I have to find a different maker how has the similar shape in LED.
  • Need website to go too, the light is oval and fits in coach. I can't change the shape because of the inset.
  • Try this website for LED marker lights. You should be able to find what you need. Try to find SEALED lights and then you will not have any problem with water getting under the lens. LED marker lights
