DHDB
Aug 23, 2014Explorer
mileshuff wrote:
A good guess would be that this trailer is a 2010 Keystone Outback. Looks like one of the longer ones. Weight maybe ok as the larger 260FL weighs about 6500lbs dry but thats without options or cargo. My issue would be the length if towing on a windy day or with passing semi's.
The TT has the same roof config of my Outback 301 BQ. TT is 33'+ and 8800lbs max wt. I wouldn't consider towing it with anything less than a 2500. I like the added safety margin of a larger truck because as road conditions change, you never know what is around the next corner. I suppose a properly adjusted Nissan could tow a larger unit like this. It just seems they would be right at the limits of there TV capabilities.
44,068 PostsLatest Activity: Apr 17, 2021
