the_c's wrote:
We have a 2015 Zinger TT that was purchased from Camping World about 2-1/2 months ago, and the problem I'm having is the battery won't hold a charge for more than a few hours once it's unplugged from the house.
I had the unit back at Camping world a little over a month ago to take care of a few warranty issues and I asked them to check the battery and charging system while it was in the shop. When I picked the unit up, I was told the battery load test and the charging system both checked out OK. It was a new unit, so I assumed I was leaving something on inside.
I spent this past weekend cleaning and winterizing the unit, so it was plugged in from Saturday morning, until about 10AM today, (Monday). When I unplugged it, It showed a full charge on the inside monitor panel, and I even checked it with my volt meter and got 12.4 volts(after it was unplugged). I got 13.9 volts when it was plugged into the house, so I'm guessing it's being charged. Less than four hours later, the battery is almost dead. There was nothing on or running inside the camper. The voltage reading when I checked the battery was a little over 10 volts.
I called and spoke to one of the service guys at Camping world, and he said that it's normal for the battery to be 100% dead withing 6 - 8 hours after unplugging from shore power. He also said that the battery wasn't covered under my warranty. Keep in mind, I bought this camper NEW at the beginning of September.
Can anyone tell me if what I'm being told is accurate before I call back tomorrow and lose my cool? I have not had pleasant dealings with these people, and if it wasn't for the fact I love the camper, I would have told them to shove it long ago due to other issues to numerous to mention.
** I traded in a 2005 Hornet TT with a 4 year old Walmart battery that would hold it's charge for almost 2 weeks before I would need to plug it in.
Thanks all!
Clearly there is still a load on that battery. You will need to pull fuses / shut off breakers to find the phantom load. It could be a propane leak detector, radio, amplified antenna, electronic thermostat, fridge, ect. Maybe there is a light turned on inside a storage cabinet??? 6 hours from full to empty is not normal.
