rlhay's avatar
rlhay
RV electric power, half not working
I used my outside 110V recepticle for a small pressure washer and it tripped the power off. Now only half of the travel trailers 110V power works. I have checked the 110V breakers and none are tripped. I can only locate 1 GFCI and it is in the bathroom and it is working fine. It acts as if a GFCI is tripped but the only one I can locate is working. I'm sure its something simple I am over looking but............
Any suggestions would be appreciated.
BTW
2003 Cruiser by Crossroads
28' travel trailer
Thanks
Randy
  • You should have at least two GFI's. Kitchen and bath, would be minimum, there may also be one outside.
  • I do have an invertor and it is working. I checked all the buttons and switches and they are all in their normal positions.
  • Do you have an invertor? When mine trips 1/2 the power in the coach goes out. Check that all buttons/swithes are set.
