hohenwald48
Aug 15, 2015Explorer
RV Problems
I see a lot of posts on this site and others about problems that folks have with their "new" campers (of all classes). I wonder how much of this is unrealistic expectations on the part of new RV ...
Lynnmor wrote:I disagree, I think it is available. The problem isn't a stripped screws, it's not putting in a new screw next to the stripped screw. It's putting 1 screw in when 3 or 4 is needed. It's using 1/8 inch plywood when 3/8 inch is needed. It's using a C channel frame when a I beam is needed. You need to find the manufacturer that is rectifying the stripped screw, putting in 4 screws, using 3/8 inch plywood, and an I beam frame. They exist. (All adjectives are meant for illustrative purposes only, not actual - Just my experience, your experience may vary).wing_zealot wrote:
You want higher quality, buy higher quality. It's certainly available. Most people aren't willing to pay for higher quality, then ***** when they don't get it. You get what you pay for.
Trouble is..... it's not available. You don't get what you pay for, for example stripped screws actually cost more than correctly installed screws. Too many people accept this poor workmanship and even defend their purchase while not recognizing the problems they just bought. If a manufacturer cannot build a product correctly, then they shouldn't exist.
