far733's avatar
far733
RV Stabilizer Positioning
I own a 30 foot travel trailer with quad bunks in the back and the master bedroom in the front. I snug up each of the scissor jacks and I use two Bal X-Chocks between each set of tires. However, there is still quite a bit of movement within the trailer.
I am interested in getting a set of RV stabilizers (either Bal Lock-Arm or Steadyfast). I was considering installing one stabilizer on each scissor jack going from side to side. This should stop most side to side motion. I figure that the X-Chocks are stopping most of the the fore/aft movement so there shouldn't be a need to mount any of the stabilzers front to back.
What are your thoughts/opinions on this?
  • It will significantly improve the movement which is quite common in longer trailers. There are other brands also you did not mention that are essentially the same. Shop around for the best price and ease of installation.
