dadkins's avatar
dadkins
RV toliet
I have a 2002 KZ Coyote Hibred. The floor of the trailer has gone soft and I have learned that this is a problem with this particular model trailer. I have removed all the linoleum and put 3/4 inch cabinet grade plywood on top. My quandary now is the bathroom. The toilet sits on the old floor which is shot. I want to recover the floor with the same material as the rest of the trailer. However, when I do this, the toilet will set almost 1 inch above the flange. Is there an adapter or something I can use to mount the toilet on the new floor and connect to the black tank? The toilet does not leak. It did previously from a cracked valve, but that has been repaired. I really need help on this.
  • There is a seal between the toilet and the waste pipe that can be stacked one on another to get height but your bolts will need to be changed out for longer ones
    Good Luck, Mike
  • Check camping world and some of the bigger suppliers
    Somebody makes a riser just for this but I can't remember where I saw it but it was in a catalog.
