jpmyers
Sep 12, 2020Explorer
RV Water heater
Our New TT (May-2020) has a Electric/Propane water heater that has become very noisy lately. If only it were not right next to the bed. But it is and the 2' proximity with a very thin wall for seperat...
Old-Biscuit wrote:
Dometic IS Atwood (Dometic owns Atwood)
Model Number will be listed on data sticker in outside compartment
IF 10gal model will be GC10A-4E
If 6gal model will be GC6AA-10E
If it is GAS/Electric Combo and you are in CG why do you have the Propane ON?
Propane Noisy then you can adjust the air shutter to control flame (fuel/air ratio)
Only 1/4 of slots should be open for a good BLUE Flame that is fairly quiet
This appears to be open a lot more than 1/4, am I missing somethind?
YES you can turn BOTH ON for fastest recovery time
Both use the same set of T-stats so both will turn on at same time and off at same time.
At night...turn the GAS off so you don't have to listen to it fire up
