patkvm's avatar
patkvm
RV Wiring
Good day all,
I have a quick question that I think I know the answer too. I need to put a refer cooling fan behind my refer, I have no 12 volt source behind the unit so I need to know if it would be safe to run the wires directly to the battery with an in-line fuse to the fan. I just want to make sure that I will not be putting a strain on the charger.
The fan pulls less then 1 amp, it is more in the range of .50 amps.
Thank you in advance for your help.
