patkvm's avatar
patkvm
RV Wiring
Good day all,
I have a quick question that I think I know the answer too. I need to put a refer cooling fan behind my refer, I have no 12 volt source behind the unit so I need to know if it would be safe to run the wires directly to the battery with an in-line fuse to the fan. I just want to make sure that I will not be putting a strain on the charger.
The fan pulls less then 1 amp, it is more in the range of .50 amps.
Thank you in advance for your help.
  • patkvm, I looked on the internet at the same trailer you have. I see that your refer is under the counter top. I think you'll be OK running a wire directly from the refer to the battery. Like was said before make sure you have an inline fuse in the wire.
  • elivi8 wrote:
    Why don't you use the Camco solar powered fan vent? Then all the wires are local.
    http://www.campingworld.com/shopping/item/solar-powered-rv-fridge-vent-system/47888
    Ryan
    This setup will not work on the 185RB as the refer has no top vent, which is the whole problem.
  • Why don't you use the Camco solar powered fan vent? Then all the wires are local.
    Ryan
  • Dometics have 12 volts behind the fridge for the controls & I would suspect Norcold would too. If you run a line from battery just remember to put the fuse near the battery. :)
  • I will look again but the refer is a Norcold N300 that is 120v and LP. The only wires that are behind it is 120 and it is clearly labeled. there is a nice wire block on the back of the Refer that has 12v terminals but they are empty and dead. There is a chase that the propane hose is in coming through the floor so I wanted to run the wires in there and back to the battery. The trailer is a Jayco Swift SLX 185RB so it is not the top of the line trailer.
  • Unless this is an old friedge with a pilot light, 2 way fridge needs 12 volts to both operate the gas valve and the igniter along with the inside light and controls etc.
  • My two way fridge has 12 volts - that's what operates the circuit board and maybe even gas solenoid.
    My 2006 Jayco has 12V power behind its fridge. If I remember correctly, its the thick 12V RED wire. I found this wire and traced to its circuit board. It has "+" beside its plug in. I then confirmed ALWAYS LIVE 12V "+" power using 12V probe tester. For my computer fan, I simply connected to this red wire - using inline fuse and manual off/on switch.
  • I would have thought that there be 12 volts behind the unit but in Jayco's infinite wisdom they only put a 2 way refer in the trailer. So instead of pulling out the refer I thought that I would just run the lead about 3 feet to the battery.
  • You will be just fine hooking to the battery.
    However you probably have 12volts going to the refer control board in back there.
    I doubt an extra .5amp would cause any problems. That line is probably fed from one of your 12 fuses in your power distribution panel.
