K_Mac
Dec 22, 2014Explorer
Safety Chains
I'm curious if twisting your chains in order to gain some clearance, is in fact taking away any strength of the chain. I 've taken links out over the years with different set ups to get my preferred l...
mkirsch wrote:
Shock cords don't make the chain any shorter.
If it's long enough to need shock cords to keep it off the ground, it's too long to safely do its job in the event of a disconnect.
Twisting the chain does make it functionally shorter, but compromises its design strength to a degree.
The "right" answer is to make the chain the proper length, but that is not so easily done if you are using multiple vehicles with vastly different chain length requirements. You can cut and cut and cut a chain but it will never get any longer. Sure you can use a double clevis to add length, but then you're fiddle-farting around with six cotter keys and six pins every time you switch vehicles.
