DWeikert
Jun 20, 2017Explorer II
SidecarFlip wrote:MN Ben wrote:
Could you use one of those swimming pool noodle floaties?
I would say no, the vinyl is too thin, but worth a shot anyway, it's cheap.
I wonder if you could stack the noodles? For tying some foam body flies for fishing I use 3M Super 77 Spray Adhesive to stack different colors of foam. Maybe use a little painters tape so the spray only coats a strip down one side of each noodle. Spray on then press together, give a few minutes to set and you have a double thickness noodle.
Just a thought...
