amxpress
Aug 14, 2014Explorer
I use a Camco water filter at the spigot and as mentioned, always run the water before connecting to the trailer to flush out the hose. Haven't had a sand problem. You can buy larger filters if you travel in sandy areas and either hook it into the plumbing or run it inline on the outside and mount it on a bracket. You might also consider flushing out your water heater.
