colliehauler
Aug 23, 2014Explorer III
mobeewan wrote:This would be my guess as well. Draining the water heater and cleaning it out. You might need to change the anode rod as well. Make sure to take the pressure off the water system before taking out the anode rod. Make sure to turn off water heater electric switch.
Are you sure it isn't coming from the water heater? As the anode dissolves you get deposits in the bottom of the water heater that look like sand which wind up in the hot water lines and eventually clog the diffuser on the faucets.
