atrerice's avatar
atrerice
Sanitizing Waterlines
Getting our camper ready to use and wondering if we should be doing anything to sanitize the fresh water lines? We are only planning on using the city water connection and not use the fresh water tank. I hooked it up, flushed out the antifreeze from all faucets, took the waterheater out of bypass and tested that. I think I found the low point drains - do I need to drain those out too? Also, do I need to drain the water heater before taking it out on the road? Anything else I need to do to de-winterize it?
