Powelligator
Apr 20, 2014Explorer
On late-model Fords they use a dual band antenna, this means that one antenna is used for both the GPS and the Sirius, as both use different frequencies. So moving the antenna on the Ford Super Duties as described above covers both music and the on-board navigation.
You Dodge Boys might be in a different boat. For example, my Jeep has factory navigation and Sirius. In that vehicle two different antennas are used for each, the antenna on the roof turns out to be Sirius only, the navigation antenna is on the dash. So Chrysler *might* be different in their trucks. I'd recommend checking with the dealer, or maybe someone here might know.
Good Luck!
Joe
Good Luck!
Joe
44,071 PostsLatest Activity: Aug 16, 2026
