More and more I see campers with satelites hooked up to their RVS at the campgrounds. I was wondering how good do they really work?
I would think if they didn't work you be seeing them "less and less",
but "more and more" tells me they are working well. :)
Here is what I did ...cost was about $450 at the time, i own the system:
DISH Network offers a 'pay-as-you-go' monthly program called 'Tailgater'  you pay, they provide the channels you choose for 30 days at which time you have the option to renew an additional 30 days or not. If not, when you reactivate it in 3 or 6 mos time, there is NO FEE to turn it back on.
If you want the DVR function, you pay a one time fee of $40 for that activation.  Every time you reactivate, you will then automatically  have DVR service.
 You can also add local channels.  You can pick your own 'HOME area' or pick local stations where you are camping but i never done that, i keep my HOME stations all the time.
Dish offers channel 213 which gives you local weather when you punch in the zip code. Multiple zip codes can be entered so you can view 7 day weather forecasts where you plan to be at your next destination.
https://www.dishformyrv.com/Im able to padlock/cable and antenna to a tree etc .
I bought one of the portable systems because i camp in the woods under trees . A rooftop dish would be restrictive.  I carry 150 ft of cable in order to find a clear shot to the S/W sky.  If you camp in an open area you have the option to place the antenna on the roof.
My 211k receiver uses only one cable that combines the signal as well as the 12v power to the motor to  spin the antenna .
It stays on during heavy rains much to my surprise because the antenna is smaller, it only gets a signal strength of 50-65, but it works just fine.
For those who camp off grid using 12v power:
A 150 watt inverter does the job with power to spare for the 28" TV, 211k RECVR and Antenna.
When I boondock, i now run the 28" tv and dish recvr off a PSW 150 watt inverter with a 12v plug (its not hardwired).
The receiver uses the same 22 watts of power if its on or off. Therefore i shut it off during the night while boondocking.
Its not a big deal because it only takes 5-8 mns to reboot it. By the time the coffee is made , the dog goes out, we are ready to watch the morning news, its all AUTOMATIC, you don't have to point it manually.
I leave the system out and set up 24/7 and never had any issue with kids touching it in the 12 yrs I've had it.
:S :h
The only issue i had was the inverters low voltage would sound when the water pump was being used and sometimes would sound when the antenna motor would scan from between 2 satellites (looking for a station , my dish flips between sat 110 and 119)
The alarm was sounding because the wiring in my RV is too light to the 12v  outlet that the inverter is plugged into.
 To solve the problem the RV could be rewired. I don't have the time to do that now so I went to plan B.
For me, the easiest thing to do was carry a separate AGM 12v battery and keep it under the dinette to which i plugged the inverter into.
 That solved the alarm sounding and the AGM battery gets charged as needed by a separate 3 stage charger inside the RV .  AGM's do not off gas like a wet cell does and can be charged inside.
