NCMODELA's avatar
NCMODELA
Scale Weights
Hi, I took my trailer (2011 Keystone Summerland 26 BH) to the scales today with the TV 2003 Yukon xl. This is what I got, tow vehicle with the TT hooked up was 6360, Both combined is 11720, Trailer was 5560. My GVWR is 7000 so I can make that with the four kids (will be about 6800lbs). My GCWR is around 13,300 lbs, So i am okay there. It took it to the city of raleigh yard waste scales, i have no idea how accurate they are. (but when you add up the TV, TT (6369 +5560 = 11920) but the scales read 11720 when both were on there)
My first question is if you subtract the TV weight with the TT attached from the TV with nothing attached that will give you the tounge weight and you have to add that to the TT weight. If i do that then i get 6240 with 680 as the tounge weight. That is 11% of the trailer weight. This is with the wdh hooked up.
Second question, I hooked up the wdh, and got the front wheels back to normal (only raised 3/4 in when hooked up, but to do this I have 6 links on one side and 7 links on the other, is this okay?
Third question, I tried to level the trailer with the hitch height and It is nose down, it measures 20" in front, and 22" in the back, is this too much of a nose down? I am as high on the hitch that i can be, if i turn it around and be at the lowest then I am still too high and the tt is nose up.
Fourth question. The trailer drove great and the car pulled it great. but it seemed to bounce in the rear end alot when the trailer bounced (more like a flex) this was only on bumpy roads.
Sorry for the long post.
