Thanks Wayne. That was my thinking. The step assembly is quite loosey-goosey. Re-drilling the holes and replacing the 1/4" bolts with 5/16" bolts should fix it up OK.
Reddog1 wrote:
I had a coworker with steps just like those. The bolt holes were too big for the bolts. I advised him to drill the holes out for the next size bolt. I think it was 5/16" diameter bolts, with 5/16" diameter holes. Used self locking nuts. That solved his problem.
Wayne.
We're planning on doing something like that. The exact dimensions are yet to be determined, but something in the 18-24" range seems ideal. I'd also like to get it below the basement for easier access to the basement.
fuelhauler wrote:
My Bigfoot was the same way with the 6 steps. I built a 22"x7' deck & hung the steps off of that. I have a fold up step on the deck & a tork lift hand rail which really helps on the stability.
