stevenal
Sep 02, 2014Nomad III
scissor steps
My scissor steps are not parallel when extended. If I extend them so the middle step is level, the upper slants down away from the camper while the lower one slants back the other way. I always though...
We just added Torklift 3 step Glowsteps to our truck camper. We attached it to the bottom of the sewer hose compartment and used the existing brackets. I cut the mounting bracket that came with the steps in half and on the steps I switched the long brackets and short brackets on the top step. I then located where I wanted the steps and attached the mounting bracket I cut in half with the curve facing outward onto the existing bracket on the bottom of the sewer hose compartment. After that I attached the steps to the curved mounting bracket. This makes the steps very stable. There is a wide gap when you step down to the first step so I inverted the step that came with the camper and placed it over the gap. It fits nicely and covers up the gap. No bolting necessary, but you do have to take it off when you fold up the steps. With this done the steps fold up flush against the sewer hose compartment. I put a racket strap around the steps when we are traveling
