My scissor steps are not parallel when extended. If I extend them so the middle step is level, the upper slants down away from the camper while the lower one slants back the other way. I always though...
I added the Ground Control Landing Gear to my GlowSteps. Not only will it even out uneven ground, it allows for fine height adjustment if your setup measures between steps.
