What is the advantage/disadvantage of one style over the other? My FunFinder has stab jacks and I'm not a big fan of them although they work fine. Is it worthwhile to switch?
While we do not use the scissor track to lift the trailer, we do use it to level the trailer if it is off a bit. We also jack the slide side a little higher before we open the slide.
You can feel when the jack is straining when you crank it.
