TrevorL
Jun 30, 2014Explorer
that is correct.
Gaffer222 wrote:TrevorL wrote:
i have been using OSI Quad with great results since im replacing alot of old sealent on my TT.... i suggest trying to remove as much of the old caulking as possible.. its a pain in the rear, but well worth the effort. also use painters tape around the caulk line so it will give you perfect lines..
Do I assume correctly that you pull off the painters tape while the caulk is still wet?
