Jerrybo66
Aug 11, 2014Explorer
Cut a piece of plywood, aluminum or metal is better as wide as the generator and long enough to set the genny on, plus long enough to run under your truck or trailer tire. Bolt the generator to the plate then pull the tire over the extended part. Make sure the generator is close enough to the tire, (touching) so a blade can't slide through. The wheel has to be moved off the plate to move the generator. No cables, chains, locks, etc........ Just a thought... :)
44,071 PostsLatest Activity: Sep 18, 2026
