westend
Jul 12, 2018Explorer
Using the adhesion promoter I have never had a bond failure. And the few times I wanted to remove something, well, kinda like using red loctite!! a real PITA to get it off, it takes some serious work.
Good information. It also points out one consideration: A user may want to install a mounting bracket that can accomodate different cameras. It would be easier to swap out cameras in the future.
FWIW, I don't have an issue drilling holes through any surface as I know how to seal them. Admittedly, the first time I installed a knot meter through the bottom of a boat hull, I was apprehensive. Since then, no anxiety. 3M also makes a carpet seaming tape in various grades. The "Extra Heavy Duty" tape bonds securely. I've used it to hold molds and jigs together for machining and, typically, it will pull apart wood when trying to release.
