CAJW
Jun 07, 2016Explorer
deltabravo wrote:
In my 811, I can see both the black tank and the grey tank through to rear door that gives me access to the dump valves. I think on a 990/996, the access door is on the side of the camper, which must inhibit access/visibility to the grey tank.
Correct. As Joe and another source have told me, the OEM grey tank wiring is inaccessible without removing the belly panel. I'll investigate the possibility of adding a new set of wires for the grey tank rather than dropping the belly panel, which will have to move with the kitchen slide. It may be all for naught as room in front of the fresh & grey tanks is very limited which may prevent accurate placement of the adhesive strip sensors.
I'm hoping someone has already done this on a 996 (hopefully without removing the belly panel) but I may end up breaking new ground here.....
