BurbMan
May 16, 2022Explorer III
It's tough to manage that extra weight when you're lifted. I would say pay attention to your airbag installation...most times airbags are plumbed to the air line with a tee so they fill together. This doesn't give you any side-to-side stability because when the truck rocks side-to-side all it does is push air from one bag to the other. Either use separate Schrader valves for a bumper fill or a check valves if connected to an onboard compressor.
Depending on the config of your 150 you may or may not have enough payload for that camper as light as it is. You may also need n HD sway bar in the rear to control body roll. I see you're in NJ, if you're planning on hitting the beach with the camper, controlling body roll is priority in the sand.
