Checkers123
May 16, 2022Explorer
BurbMan wrote:
It's tough to manage that extra weight when you're lifted. I would say pay attention to your airbag installation...most times airbags are plumbed to the air line with a tee so they fill together. This doesn't give you any side-to-side stability because when the truck rocks side-to-side all it does is push air from one bag to the other. Either use separate Schrader valves for a bumper fill or a check valves if connected to an onboard compressor.
Depending on the config of your 150 you may or may not have enough payload for that camper as light as it is. You may also need n HD sway bar in the rear to control body roll. I see you're in NJ, if you're planning on hitting the beach with the camper, controlling body roll is priority in the sand.
Thats good advice BurbMan thank you. After reading more about plumbing the bags this waythere seems to be a con. Curious to hear your thoughts. If you develop a leak or a bag fails, you would have air in one bag and not in the other which would lead to a lop sided load. Whereas if one was leaking but not the other and they're plumbed together, they would slowly loose pressure equally. Or is this not really that big of a deal?
