AnEv942
May 17, 2022Nomad
Only add a leaf style that's bolted (replacing center pin) to existing bottom of spring pack, under u-bolt plate, would work with air bag mount. May add additional lift increasing distance between top of pack & frame, space air bag uses. Check factory u bolts 'may' not be long enough, supplied bail u-bolts for lower air bag mount 'may' not be long enough.
Skyjacker rear blocks set on top of factory blocks.
Tying air bags together would amplify any lean and roll, air from loaded side pushed into unloaded side.
Wonder if over the top helpers leafs (rated more #) would be enough- sure would be less work
