plasticmaster's avatar
May 28, 2020
Service Trailer Brake System message
On my lunch break today, I drove my truck to the store, which is 5 minutes away. While driving the "service trailer brake system " message chimed and came up on the dash. It did this several times. I then drove 5 minutes back to work and it happened several more times. When I went home after work (about a 30 minute drive) it never happened. I was not towing anything. Truck is a 2014 Silverado with factory brake controller. It's never done this before today. Has anyone experienced this? Should I do anything before I tow my TT end of next week? Thanks.
  • The times up meter has run out on your trailer towing module, go to the dealer and give them more money. Probably corroded wiring shorting out somewhere.
  • It’s not just GMs that have this glitch. But think I’ve seen it more in the ‘14 and ‘16 Chevys I’ve had than others.
    It’s never been an issue when I hook up later.
    Just test it with your camper first before you actually need the trailer brakes I spose.
