OhHolly
Feb 16, 2016Explorer
Set up ok?
We are about to finalize purchase of a Starcraft ultra lite 27bhu. It's 33 ft to the tongue and will be max 7700 loaded. We have a 2015 Sierra Denali with the 6.2l. Weight of the trailer is 80 perc...
2012Coleman wrote:
Here - I'll make it easier for you....
Cat Scale Locator
Like I stated before - if you can't come out with a significant cushion calculating the weights using gross numbers - not guesses as to the amount of weight you will be loading, then if your concerned about safety, then weigh your loaded truck.
JMO - do what you like, or follow the advice that is easier to follow.
