We are about to finalize purchase of a Starcraft ultra lite 27bhu. It's 33 ft to the tongue and will be max 7700 loaded. We have a 2015 Sierra Denali with the 6.2l. Weight of the trailer is 80 perc...
Well the dry weight of that trailer is 6200 lbs. I always say to add 12-1500 lbs to the dry weight to get your loaded ready to travel weight. then figure on 12.5% of that number to get your loaded tongue weight which would be 975-1000lbs. The only issue with the 27BHU is that the trailers axles (and probably tires) will be maxed out. It has a small CCC of 1500lbs.
