Flapper wrote:
New Grand Design TT (2670MK), Andersen "No-Sway" hitch. The truck in my sig (yes, it has 17" "E" tires). Andersen instructions are rather vague about proper adjustment for weight transfer, essentially "just eyeball that truck and trailer are level". Considering that my unloaded truck is a bit tail high to start....I'm unsure where to put my level to verify - on the bed?
Did measure the front wheel well height. With full load of the trailer, and no WD, the wheel well rises 3/8 inch above unloaded. After really cranking down the WD (9 threads, as those with Andersens may know), it currently is at 1/8th above unloaded.
In a short drive, it seemed a little "wiggly", but no sway from semi's passing me. Only prior towing had been a lot with a small Jayco fifth, and a 3,000 boat, so unsure as to how "solid" (or not) a long, heavy TT should be as compared.
Is there a better way to rough it in, before I can get to a scale to really verify?
What I would do is back off from the 9 threads until you notice any deterioration in handling. I got the best results with between 1/8" and 3/16" of bushing compression. 3/8" rise in your front end is not a lot to start with.
