Dream_Girl
Aug 25, 2015Explorer
Help! Installing Andersen No Sway WDH
I spent 2 hours yesterday trying to install the WDH with NO success...
The first challenge I have had was the bottom ball pin didn't fit the triangle plate hole, After 30 min of messing around I got it in, it was a very tight fit, now I doubt that if I ever be able to get it out...
The second challenge I have had was to align the triangle plate to the RV tongue, the manual indicate to NOT use a hammer, instead use the vehicle, it took me a while to get the hang of it – but I did it right.
The third challenge I have had was installing the brackets, as soon as I start tighten the bolts they slide forward, resulting in uneven distance from the RV coupler
In the end I mange to install everything per the manual, the towing vehicle was leveled and all look good…. Until I start driving away in the parking lot.
After a few sharp turns I park straight as a ruler and I notice that one of the chains was loose while the other was super tight – is that normal? My guts feel tell me that NO.
Tonight I will try installing it again (from the start) I will go through all the steps in the manual again and see, maybe I missed something?
Please help.
Please help.
