elm3420's avatar
elm3420
Setting up Equalizer Hitch
I am redoing the setup on my tv and trailer because I purchased a different set of tires for my tv. I went from 245 to 265s. When I towed with it I had a lot of sway when I towed with the new tires. When doing the new setup I realized I cannot adjust the hitch down any more which to me suggests that I need a different shank for the hitch. Just looking for some opinions. The top of the ball measures 23.5. The top coupler measures 20.25 when the trailer is level. This seems to me that this is too much difference between the two.
  • That does seem like a big difference. Yes, you can purchase a new shank, which is what I had to do. You'll probably get sticker shock....they're pretty pricy for a chunk of metal. But, well worth the price if it helps you tow correctly.
