crcr's avatar
crcr
Several Questions about Issues with Slide out, (pics incl)
Issue #1: On the top of the 12' slide on my 2011 Jayco 256RKS TT, there is some kind of tape near the outer flange of the slide, and the rubber seal where the slide goes in is starting to peel back said tape in several places along there. Pic of the problem is below. Obviously, this will only get worse with time. What is the best repair solution for this? Is there a specific white tape I should use to cover this edge that is beginning to peel back? Or some kind of adhesive I should glue down that peeling edge with? Please advise.
Issue #2: On the top corners of the slide next to the body of the TT, when the slide is fully extended, there are matching almost identical bubbles at each end. Below is a pic of one of them, taken from the roof of the TT looking down on the slide. There is no break in the rubber material, and the bubbles feel spongy, like there is either some spongy material inside, or trapped air.
Since these two bubbles are almost identical in appearance, I wonder if it is supposed to be that way. Is there a problem? If so, how should I fix it?
Issue #3: When the slide is fully closed, on both the front and back, the slide closes much tighter at the top than at the bottom, where there is a gap, such that the seal doesn't appear to me to be quite sealing at the bottom. See 1 pic of the front edge & 1 of the trailing edge of the slide below. I haven't yet noticed any leaks, but we have only had the trailer a few months, and haven't driven it in rain yet. Is the slide supposed to close this way? If not, is there a way to adjust it?
I apologize that several pics orientation is off 90 deg, but I had them orientated correctly and the site software switched them 90 deg off.
Any expert advice would be greatly appreciated!
