ret_usnExplorerOct 25, 2017sewage valves.On our last trip I noticed the gray valve was leaking and dripping at cap. Dumped before leaving. Just got under to attempt to replace both dump valves since this is a 2004. Found a box with pipe in t...Show More
LynnmorExplorer IIOct 25, 2017If you might use the trailer In freezing weather, keeping them up inside the belly would be best.
Related ContentSewage valve stuck openSewage FolliesWaste/Sewage SystemSewage odorbigfoot 2008 sewage valve repairs
