Grit dog wrote:
swimmer_spe wrote:
Greene728 wrote:
swimmer_spe wrote:
Grit dog wrote:
swimmer_spe wrote:
Grit dog wrote:
Since the comprehension is lacking here, I would suggest putting it in tow haul mode and let the truck do what it does. Newer fords are semi idiot proof and won't hunt endlessly for the right gear.
If you read my original post, it stated I was in Tow/Haul mode.
Sorry, wasn't suggesting you didn't have it in T/H. Just saying I've put a bunch of miles on the newer Ford 6 speeds and the transmission programming is pretty spot on for set it and forget it. It doesn't need to be babysat like some transmissions that shi(f)t all over themselves.
So, I guess I can leave 6th available and let it go in there. Which means it is time to talk to the dealer about why it was hunting.
Wow. Nothing else to say.
With all the bouncing back and forth, and the information provided in the owner's manual, there seems to be a lack of full understanding whether we are doing things that the truck is designed to do or not.
Remember, just because you do something, doesn't mean you should. And just because many people do the same thing, doesn't mean it is right.
Common, sound practice is to quit using a gear if the engine can't consistently pull that gear. It's not immediate transmission death, usually, but shifting unlocks the torque converter which creates heat.....and it's annoying. I'd rather listen to the engine sing along 500 rpms higher all day rather then hear it not be able to make up its mind all day.
After 8 pages, my common sense is now been told is wrong. Common sense tells me that the computer will do what is best, and in Tow Haul mode, if It cannot be in a gear, it will not put it there. So, why should I do anything to prevent the computer from doing what it is designed to do?
Common sense tells me that a lighter, more aerodynamic trailer should tow better than a heavier, less aerodynamic trailer.
So, please for give me for getting annoyed with those that would mock my choices and mock everything without anyone telling me why it is doing what it shouldn't be doing.
