Bedlam wrote:
As posted, this has to do with pressuring the tank.
Last time I checked, opening the drain for a sink will force water into the grey tank. Once the black tank gets so full, flushing "could" pressurize the tank. Note: I'm not saying it is exactly the same thing. ;)
In any case, getting a tank hot after filling with cold liquid (water) will pressurize the tank if there isn't sufficient venting. Likewise, gas given off from a mixture in a tank expanding could also cause pressure.
Since AF seems to have this problem more than any other manufacturer (based on reports to this forum), they seem to need a design change. There are many more Lance campers out there than probably any other brand, and I don't think I've heard of this issue with a Lance, for example. I do remember a band breaking on "one" Bigfoot.
At the end of the day, most people don't read the manual! If this was a car, there would probably be a recall or TSB. I don't fault AF for having a design mistake...it happens.
