manley
Oct 29, 2018Explorer
Description
Lea en espaƱol
Bilstein's ride height adjustable 5100 Series replacement shocks for coil-over design front suspension pickups utilize the vehicle's existing stock coil spring.
The 5100 Series (Ride Height Adjustable) shocks feature multiple snap-ring grooves on the body of the shock to accommodate different spring seat positions, allowing height adjustments from 0" to 2.5", depending on the application. By raising the spring seat position, the factory rake can be altered to achieve a level front to rear ride height while accommodating up to 33" diameter tires.
Bilstein's patented digressive self-adjusting valving delivers improved damping control and a smooth ride on all road surfaces at any speed.
Zinc-plated bodies
Self-adjusting deflecting disc valving
High-flow piston reduces harshness
Independent rebound & Compression Tuning
Larger Working Piston Area for Exact Damping
Superior Control for Large Diameter Tires
Lea en espaƱol
Zinc-plated bodies
44,068 PostsLatest Activity: Jun 27, 2026
