Guys thanks for the quick response. On that other board I hear crickets. GVWR is 11,500lbs. Tare weight was 7,940lbs. Rear axle does come in at 7,050.
Tires are load range E 10 ply sidewalls with a 3525lb max load rating. Think I'm good there.
I spent 24 years on the road so I know about weights and why it matters. I've seen pickups bent in half and famlies killed because of negligence. That being said, I think I am over thinking this.
I bought this truck used with 53,000 miles on it. The truck was used to pull a gooseneck trailer and still has the BW hitch on it. It only weighs 75lbs, so I left it in there. It actually adds another crossmember between the frame rails. Also it has helper springs installed by previous owner.
I think it's time to stop thinking and go for what I want.
