JimK-NY wrote:
My long bed transfers several hundred pounds to the front axle. That helps considerably. Second a long bed allows selection of a longer camper. With a short bed all the weight is likely to be on the rear axle and if the center of gravity is not substantially in front of the rear axle, the rig is not going to handle well. Look what happens when a trailer is loaded with too much weight in the back. Keeping the weight forward is going to help with the ride.
Short bed campers have the weight centered over the axle also, it's not like they have the weight at the rear unless you put a long bed camper on a short bed truck.
