Longshore wrote:
There are, apparently from my research, many truck camper rigs that are overweight. I do not want to be one of them. I will weigh things like kitchen ware as I load them. I have a telescope that weighs 40lbs. After all is done, if I need to upgrade the tires I will do it.
You should be OK with the Wolf Creek. It will be a decent sized rig which your truck should carry even if it totals a bit over the GVWR. Timbrens, Supersprings or something similar are low cost and ease to install options which can give the truck suspension a bit extra if needed.
BTW, if you can find one I recommend looking at the Northstar Laredo or Adventurer. They are similar to the WC but better engineered and better built.
