If it were me I would get it all back to a standard RV connection - somewhere something is going to happen and burn up all of your 120VAC items inside the trailer or hurt your dog or worse yet your kid...
Your RV trailer gets its only frame ground through the standard RV 120VAC connections with shore power...  Without proper grounds when connected to shore power connections could be a shocking experience for you
Nothing should be hokie pokie or things happens out of your control...
I am probably jumping the gun here with my safety hat comments - things may be ok once all of this identified properly... You have to be extra cautious working around electrical connections or something or somebody gets hurt because someone thinks they can do a big red neck engineered short cut here and there to save a few dollars. If it wasn't for folks being safety conscious all of our 120VAC receptacles might look like this. Can you believe you can order one of these today...
instead of this
Just my thoughts...
Roy Ken
