Hey guys, new to RV'ing and have a quick question. I have done some research regarding this, but most of the things I'm finding pertain to different amperage and which type of adapters to use. I h...
What is the battery voltage when plugged in? Looking for about 13.6 volts. Otherwise your converter might be off, stopped working or a fuse/switch is open.
Generally the converter should supply 12v power with or without a battery.
