Ty151
Jan 29, 2019Explorer
Shore Power??
Hey guys, new to RV'ing and have a quick question. I have done some research regarding this, but most of the things I'm finding pertain to different amperage and which type of adapters to use. I h...
burningman wrote:valhalla360 wrote:
Lights and water pump run off 12v...disconnect the battery and you had no 12v.
No reason to disconnect the battery when plugging into shore power.
The power converter in camper does provide 12 volt DC power and everything should be working whether there is a battery present or not, when plugged into shorepower the battery is entirely unnecessary.
That’s why that device is called a converter.
Either your converter is dead or something is turned off or disconnected.
