Hey guys, new to RV'ing and have a quick question. I have done some research regarding this, but most of the things I'm finding pertain to different amperage and which type of adapters to use. I h...
My other question would be, does it require a short amount of time once plugged in to shore power to revive 12v power? The way I was doing it was plugging in my generator with a 30-15 amp adapter, then immediately went to the outside patio light switch and turned it on with no luck. Does it require some time to be “converted”?
Also, what’s the easiest way to test the converter once I locate it?
