schlep1967
May 14, 2015Nomad
jbarkley wrote:
Correct me if I am wrong but dont you use the slder only when in a tight spot and not towing?
Depends on the hitch. On the pullrite It slides every time you make a fairly sharp turn. Fully automatic. So if you are trying to access the elusive fuel pumps at a tight gas station you do not have to get out and manually unlatch the sliding mechanism, then get back in and pull front to slide the hitch, so you can turn sharp. The pullrite just does it with out you even thinking about it. Of course you can "not" think about it with a manual slider or non slider also. That is when you replace the window like above.
